doxiemom11
May 02, 2013Explorer II
You will have to clean anything that you can and for wood, clean it with Johnson's Oil Soap. Use the ozone machine (when you are not in it) and keep doors and windows open when you can. Any fabrics will hold the odor. After cleaning a few times, you should be able to remove it. Be thorough! Frebreeze
If painting - used a sealer like Bullseye or Zinser as your primer - then paint.
38,778 PostsLatest Activity: Jun 06, 2026
