chrisandoctavia wrote:
We have a 2007 Itasca Impulse 31 foot C Class and have managed to trip some breakers in the A/C circuits
It was cold this morning and we had a small electric heater running, but must have accidentally plugged in something else that drew a lot of power in a totally separate A/C socket not realizing it was on the same circuit
We have an on-board Parallax Series 7300 Power Controller (pictured below) - and have lost power to a number of our A/C sockets (fortunately plenty of others are working OK)
As suggested in the manual - I turned each of the circuit breakers shown below on the left hand side of the panel off and then on again, but unfortunately this didn't reset the dead sockets
Does anyone have any suggestions of what we can do to try to reset themThanksChris
For the record. When air cond and or heater is used in any RV you can NOT plug anything else in it will always trip.
Unless the previous owner removed it there IS a gfi outlet in your coach....somewhere. It usually is located in the bathroom. If you don't find it I would open up that outlet.
I'm really surprised one of those breakers is not marked GFI.
Did you pull the
'fuses' in the converter and look to see if any of those are blown? There is a fuse for the GFI.
