Artum_Snowbird
May 05, 2015Explorer
Often what happens is someone tries to winterize this line once the system is already pumped up to pressure. Pushing on the tip inside the valve then releases pressurized water out the check valve, and the O-ring inside becomes unseated as it's meant to work in the other direction. When I replaced mine I just undid the screws and pulled it out, replaced the check valve with a new one. $10. or less.
38,766 PostsLatest Activity: Jan 10, 2026
