Dale_Traveling
Jan 16, 2017Explorer II
I'm guessing the seller is referring to the 12VDC stuff. Could be as simple as the battery is dead. Could also be the disconnect circuit has failed in a disconnect state or a high amp fuse between the batteries and the coach has opened. Another potential source is the AC to DC power converter has failed and the batteries are dead. Not a difficult problem to chase down if you do a bit of homework first.
38,763 PostsLatest Activity: Dec 05, 2025
