Bill.Satellite wrote:
If you see any NASCAR RV's head down the road you will see most are pulling a P/U behind the RV and a full sized golf cart is in the bed. The electric wheel chair might also fit depending upon the size of the cart you use. Ohterwise, a lift like shown above will do a good job for the cart and you can install a chair carrier on the back of your tow vehicle which will be tagging along behind the coach and golf cart lift.
Depending upon the length of your coach and the size of your towed, just be sure you don't exceed any legal limits such as the 65' max in CA.
X2
I bought one of the smaller cargo carriers to attach to the back end of my Toad. Amazing all what you can carry on it. Mine was rated for 500 bls.
They also make cargo carriers where the short end drops down as a ramp. No heavy carrier and motor or lift like the wheelchair carriers have which adds a ton of extra weight to the back end. Real inexpensive also.
So let's see......you buy a truck for a toad, put the golf cart inside the truck bed, add a cargo carrier to the truck and add your wheelchair. Whew! I think you are ready to go!!:C
