down_home
Dec 27, 2020Explorer II
Two full wall slides in addition twin bedroom slides 45-47 ft.
Living in it for awhile you really want all the space you can afford.
We lived in our 38 ft for a year recently.
Not going to do that again.,,,in the Arizona desert at our age. We usually spend 90% of our time outside or away from the coach but not in 113 degree heat, and nothing but dirt.
So where you spend your time depends lot on how much creature comfort you want from your RV I think. Our next Mh will have the large as we can get TV that rises up, if required even if blocking a window. Big windows and a window wall would be welcomed with auto tint of darkening. No fooling with shades and such. King bed, and a sofa bed if you happen to have company. At least 5 gpm per @55 psi and no lower pump and remove the flow restrictors from the shower!Get a shower wall if you can and a bidet, I don't care what Spouse says.
Dish washer a must and convection/microwave, and if full electric, flat glass stove stop. Washer and dryer not washer/dryer. The couch should be big enough to stretch out on for a snooze. Swivel Rocker Recliners a must. Dining boot if you like but a table and chairs for our next one. utilities sewer, water, and electric, all on power retracting reels! Largest awnings you can find and self retracting if wind kick up. If you set up in RV Resorts you really want to be able to sit out under the awning on the side away form the sun in the evening or the morning, maybe,just like at home we have two large, west and east porches.
Enough storage reserved for drain though pad or carpet, as you don't want to damage grass if you camp on grass. The ones with half inch or one inch holes all over and through the surface.
you want to RV on a lake or wherever, and go Antiquing or everything in deep. Daily maintenance is not something you want to be deep in. You left home to leave all that behind.
