msturtz wrote:
lcseds wrote:
So I saw a mention of it earlier, but if one had to choose between a low end DP like a Winnebago Forza vs a gas unit, would that be worth the extra bucks? Or would you have to go to a higher level DP to make a significant difference. In other words, how would a entry level DP stack up against a mid level gasser?
For us we started with a higher end gas and ended up with an entry level DP.  It still has Corian counter tops but vinyl flooring and low end wood finishes i.e. photo finish.  The OEM chose an Allison MH2100 transmission and Cummins ISB 300 rather than the more common MH2500 and Cummins ISB 340. This limits the maximum GVWR to 26,000# and GCWR to 30,000#.  These types of compromises are common in this price range.  Funny thing is the Freightliner Custom Chassis my OEM chose was actually a 28,000# GVWR 33,000# chassis but was "de-rated" because of the transmission. These sorts of compromises were ok with us because all gas units max out at 26,000# and GCWR of 30,000# but you are limited to a maximum toad weight of 4,000# for some and 5,000# for the rest. This would prevent us from towing our Suburban and possibly even our Acadia.  This is where the compromises come into play.  We chose to limit our options to units that have a 6,000# minimum tow rating.  As it is our entry level DP has a maximum tow rating of 10,000# provided that GCWR and GVWR ratings are observed.  We also don't like the long rear overhang and long turning radius of a gas unit.  Now that we have our DP the ride is very nice compared to our former GAS MH.
The long overhang of a gas coach is something people overlook.  I guess it's because of the drive shaft, but it does add some complications.
