peterman1's avatar
peterman1
class a in storage for over a year
my class A is a gasser and has been in storage for over a year. the gas that is in the tank has also been there for over a year. I read that gas is only good for 6 months so should I drain the old gas? its a 2008 fourwinds hurricane with a ford v10 engine.
  • You will be OK. Yes the gas will go bad, but it will still run and drive. Stop and completely fill the tank and drive it till it’s near empty then refill it.
  • Add as much fresh gas as you can and give it a try. I would use some additive to take care of any moisture that may have developed in the tank.
  • Too bad you did not add Stabil to the gas before storage. That would keep it good. I would just run it and hope.
