toedtoes
Sep 15, 2021Explorer III
valhalla360 wrote:toedtoes wrote:
I do wonder if putting a sign ON the low bridge/overpass/tunnel is enough. I've been on some roads where it is impossible to pull over or turn around or exit within visual distance of the potential hazard. What do you do?
I've seen signs that indicate "last exit before bridge". Should there be signs that say "vehicles over 9' 8" exit now" so the driver can avoid the hazard. Especially in heavy traffic, you could find yourself "pushed" forward.
Approaching SB (direction of MH) all well in advance of the bridge:
There is a low bridge sign with the height.
There is a narrow bridge sign.
There is a curve warning sign with 15mph advisory speed.
There is the sign on the bridge.
There is the large bridge beam at eye level.
It's a straight and level wide open approach.
It's a rural 2 lane 2 way road that doesn't appear to be particularly busy.
Doesn't sound like that was a factor in this case then. But I wonder if it is in other cases.
