rlw999
Sep 15, 2021Explorer
toedtoes wrote:
I do wonder if putting a sign ON the low bridge/overpass/tunnel is enough. I've been on some roads where it is impossible to pull over or turn around or exit within visual distance of the potential hazard. What do you do?
I've seen signs that indicate "last exit before bridge". Should there be signs that say "vehicles over 9' 8" exit now" so the driver can avoid the hazard. Especially in heavy traffic, you could find yourself "pushed" forward.
Google Streetview shows a big yellow diamond sign a 100 feet or more before the bridge, also warning of the low bridge height.
You can also see 2 unused posts just in front of the bridge that looks like they are about the same height as the bridge, I wonder if those used to hold a breakaway barrier that would warn overheight vehicles before they hit the bridge. That seems like the best way to keep this from happening.
