Effy
Jun 02, 2015Explorer II
Let's not forget the CHF. Cheap handling fix is free and takes about 15 mins. Do a search on here. Essentially it moves the position of the stock sway bars to a different set of holes. Dramatically reduces sway and body roll. I did mine and hardly get any truck push or wander any more. Did it in 15 mins in my driveway and cost nothing.
Also, as others have said, load your coach like you are travelling (water, food, people etc) and weigh your coach if not all 4 corners then at least by the axles, and set your tires PSI accordingly. The sticker on the MH for recommended pressure on mine was off pretty far. Weighed it and set to the tire manufacturer's chart and rides much better.
Do those 2 things, for free and you may find you won't need to spend any money on aftermarket stabilizers or anything else.
