timn's avatar
timn
Class a or c
We are looking at both wanting a diesel. Will the a handle better and what would be the real world difference in milage thanks.
  • In my short (2yrs) I have come to the following opinions:
    Class C generally have lower roof height than Class A.
    Class A generally have more generous floor plan size due to longer length and are a bit more comfortable.
    Class C are somewhat easier to maneuver due to shorter length and lower height.
    My 24 foot Class C gets 15 MPG on diesel, yours may vary.
    Class A most certainly have more than one slide, sometimes three and have lotsa floor space when parked.
    Class A will probably have a much bigger towing capacity than Class C.
    More Class A than Class C that I have observed have a auto-deployable satellite antenna.
    Thare are Class A that cost close to 1 Million USD. No Class C that I ever saw even comes close to that. I surmise that you are not looking for the upper cost level.
    I believe that Class A gassers are generally less available than Class A diesel which are mostly pushers (DP).
    Class C come with many chassis sources including Ford, Chevrolet, Mercedes Benz/Dodge (see Sprinter), and probably others.
    Personal experience: Noise is not objectionable even with a front engine, it has good pulling power up hills even when towing. M-B does require use of certain approved oils and such.
    Since I suspect your are rather new at this since you asked about this, I urge you to look at floor plans of prospective units as this will give you the best experiences IMHO.
    Just added this: Class A definitely have more storage apace in the basement than Class C.
    Happy trails and the best of luck to you in finding your rig. I hope it is as close to perfect for you.
  • ClassC diesels are very rare and owners complain not only about the noise, but also about finding a service that want to deal with them.
    I am exited about SuperC, but never did own one.
    I think they deliver extreme reliability coming from commercial designs, are way safer in accidents than even higher-priced Class A and can tow 40,000 lb.
    That is my theoretical research, not the real experience.
  • Class A diesel is very quiet, at least mine is. We've had gas for about 40 years and the diesel make a great deal of difference. Quieter, smoother ride. But it is really all about the floor plan, and in the past, for many reasons, the Class A had the best floorplan for our family's needs. One thought about a Class C. Sit in the cab and then maneuver out of both seats and walk to the back. Now think about doing this procedure after driving for 2 hours and wanting to stop for a rest. At my age, with my back and knees I cannot easily get out of the cab and exit into the coach.
    Best to you and yours, and Happy Trails.
  • cvbdsl wrote:
    Not a lot of information to go on to comment.
    Diesels are available in class A and C (and Super C).
    Do you know any of your requirements (floor plan, length, towing capacity, budget, new or used, planned usages -part time or full time, towing etc)
    If your only concern is mileage, yes diesels do get a bit less MPG and cost slightly more to operate, but the trade-off is that you usually get higher end finishes, greater towing capacity and overall great reliability and generally better handling/ride due to the airbags.
    I get roughly 7-8 MPG on my 2003 DSDP.
    Let us know more of what you want:B.
    On the class A side diesels get as good and usually better than gassers fuel mileage wise from my experiences and are way higher quality wise
  • Not a lot of information to go on to comment.
