Smitty64
Jun 17, 2014Explorer
Class A towing
New to Class A travel and looking for dingy recommendations. I have been looking at Jeep Wrangler, Subaru Forester, and Honda CRV. Looking to tow 4 down
BobGed wrote:
If you're looking at new vehicles I would like to recommend the 2014/15 Jeep Cherokee. I previously towed a 2011 Wrangler and didn't think anything could be any simpler to tow, but the Cherokee is.
Foot on brake pedal, put the ignition in the On/Run position, but do not start the engine. Shift trans into Neutral. Using a ball point pen or similar object, press and hold the recessed Neutral button until it stops blinking. Shift the transmission into Park, turn the engine Off, exit the vehicle and lock the doors.
No fuses to pull since there's no drain on the battery, and you can tow it as fast as you want as there are no manufacturer maximum limits.
I would suspect the Grand Cherokee procedures are the same, but that puts you out of the category of Wrangler and Honda CRV.
