Old-Biscuit
Oct 11, 2014Explorer III
You have 5 switches
The 'chart' shows position for each of the switches for each of the 4 function (FILL; USE; DRAIN & WINTERIZE)
Just flip the switches to match chart for the function you want to perform.
Potable water hose hooks up to connection above shower for FILL and USE functions. FILL puts water into fresh water tank......USE is for 'city water' vs using on-board pump.
WINTERIZE.......yes---hose underneath goes into RV Anti-freeze bottle and then you use on-board pump to suck out of bottle and pump thru hot/cold system
38,766 PostsLatest Activity: Jan 10, 2026
