AikenRacer2's avatar
AikenRacer2
Class A window seals
I have a 2012 Thor Tuscany 42' motorhome. The driver's side window system consist of 4 sections. All four appear to have fogged up when the sun hits them. Looks like the seals are gone. There has to be a way to fix this without replacing the windows. These are insulated windows. Any ideas on what to try?
Thanks!!
  • I just had mine fixed at Darren Thomas Glass Company
    251 Commercial Court
    Sebring, FL 33876
    https://www.neverfogrvwindow.com/
  • If your windows are just fogged and not white from acid etching, then yes they are repairable. They will need to be removed, separated, cleaned to perfection, new spacer installed, resealed and reinstalled.
    Depending on your skill set, it can be a DIY job.
    Richard
  • AikenRacer2 wrote:
    I am in South Carolina
    Are you going to fix it or have someone do it.
  • There are a couple of window repair places in FL. What part of the Country are you in?
