Horizon170 wrote:
candlback wrote:
mlts22: I donno the type of connections. An RV repair place in Eureka, CA put them in. There is no leak until the water heater is at max temperature and the pressure is so much that they leak a bit.
Now I keep an eye on it and turn the burner off when I think it is max. We only use the heater for onboard showers. Not the best, but it works for me.
Your water heater should have a sensor/adjustable thermostat you could turn down. I'm not familiar with all brands though.
Pilot light type...yes
Electronic light.......usually a pre-set t-stat
Atwood.....normal t-stat 140*F ECO t-stat 180*F
Suburban....normal t-stat 130*F ECO t-stat 170*F
Some lower preset normal t-stats 120*F and Atwood has an adjustable t-stat (110*-150*F) to replace normal t-stat
OP......Furnace is biggest propane hog
Just heat water when you want hot water..........takes about 20-30 mins on propane............little longer with really cold inlet water.
