jcb47769's avatar
jcb47769
Class C 1994 Passport by Cobra engine troubles
Hi everyone, my wife and I are new to this. We just bought a 94 Passport by Cobra, and on the drive home she started acting up. First off we lost the alternator belt, and didn't find out until we arrived home (replaced it now). That isn't the problem now, but I mention it in case it could be connected to our other problems.
First problem is lack of power on uphill. RPMs go up no problem, but it feels like we are actually slowing down. If the pedal is floored, it won't shift at all, just races the engine and no power. You can slack off the gas, and she changes gear, but still really laboring over even the slightest hill. We can't realistically get over 50 mph unless it's downhill.
Second problem is a peculiar whistling sound from under the hood. I haven't been able to locate it yet, but it only happens when you hit the gas - nothing at idle, and it goes away momentarily when the engine shifts and RPMs drop.
Help! We don't know if we just bought a lemon, or if this is something we can fix, and we basically gave all our money to buy the RV, so exploratory surgery by a mechanic is likely out of the question. I'm mechanically inclined (I've replaced inboard engines in boats, and some transmission troubleshooting, etc) but not a mechanic.
1993 ford e350 chassis, 27k miles
Thanks!
  • You need to post what make and model of the chassis.
    How many miles are on the odometer/
    Lack of poweer could be from dirty fuel filter.
    Noise could be a vacuum leak
