Bobbo wrote:
Sfla2 wrote:
slatsonly wrote:
An excellent accessory that allows for charging of the chassis battery from the house batteries while hooked up to shore power or when running the generator is the Ultra Trik-L Start. Easy to install and not very expensive (<$50?).
I am very pleased with my Trik-L Start purchase. Trik-L Start
Don't understand why u need a chassis bat charger, as its not being used at all when pluged in. u can leave u car sit for mo. , will still crank
I installed a Trik-L-Start because my chassis battery would run down every winter even though the RV was plugged in 24/7. When I killed the battery, after about 3 winters, I replaced it and installed the charger. The battery never ran down again. That was 6 years ago.
sorry abt what i said as u can see i'am in Fl not use to COLD winters also use rig all yr
