Kinda true, but not totally. The LD uses (or did on my '04 & '06) particle board in the floor. There have been incidents of the black tank pulling the mount bolts thru the floor on certain models.. Of course this will only happen if to have a full tank. Cause is related to the water tank & pump being sources of leaks being located above the floor over the black tank.
tjfogelberg wrote:
Both Lazy Daze and Nexus use plywood ...Nexus for the bed platform. The entire shell of a Lazy Daze is plywood including the bottom of the storage bays.
