chevyman2
Feb 23, 2015Explorer
The fresh tank is generally under the bed (In a class C) or in an area where heat from the furnace will find, therefore the fresh water tank will not freeze (as long as your furnace is working).
The waste tanks can and do freeze (if not heated). Then they can not be dumped (emptied) until the thaw out.
38,782 PostsLatest Activity: Sep 20, 2026
