AJR
Oct 16, 2017Explorer
Not sure how accurate this will be.
Safe - T – Plus is like a shock with two opposing springs. One on each side of the piston. The springs are strong enough to center the piston if no external pressure is applied. The install is not hard. But you may have to adjust the placement of the device if the wheels were not pointing straight down the road when doing the initial install.
Safe - T – Plus helps keep the wheels pointing correctly on very uneven roads. This I know to be true from personal experience. They also say it does the same thing when a steering tire blows out. I have not had that happen yet.
