JaxDad
Dec 13, 2014Explorer III
Ditto the above comment. Unless it's ridiculously cold (like below zero F.) I never need to run the furnace.
However, I do partly (depending out side temperature) open the rearmost roof vent which is the washroom on my unit, and set the heater to dashboard only with the center vents pointed straight back between the seats and the two outer vents just barely poem, fan on second highest and heat nearly full hot. The vent moves most of the heat down the back and keeps the folks up front comfy.
If it's 25 F. outside I can keep all of the interior above 60 F. without any troubleoing it this way.
38,776 PostsLatest Activity: May 15, 2026
