bill257 wrote:
I got the Rig pressure tested couple of weeks ago and found lot of spots in front cabin area with leak.They all now sealed.
Hope everything works out for you. Not trying to scare you but here's my experience with the same deal.Got mine pressure tested,found the leaks,sealed them up,everything good.Had a little staining on a removable panel under the front window that annoyed me so I thought I would remove it and clean things up.Saw some black stuff under the panel so dug a little deeper.Well...as it turned out,all the wood framing including the front top and bottom roof corners was completely rotten and moldy to where the floor meets the cab.The only thing holding it together was the waterproof foam insulation being glued to the luan flooring.The sidewall was actually starting to separate from the bottom fiber glass.There was standing water on top of the bottom fiber glass panel and it hadn't rained for weeks.After 3 weeks of complete reconstruction,it's better than it ever was from the factory.Just telling you what can happen...
