Mich_F
Feb 08, 2015Explorer
Juzaxadar wrote:
I actually removed everything in the cabover including that crossbar and the inner window frame. Even with everything removed I couldn't make the side wall budge. I haven't put it back together yet. It'd be nice to figure out how to remove this stuff and see.
The sidewall won't budge because your front wall, even if it has rotted wood, is holding everything together. The front wall is screwed into the front edge of each sidewall, tying the cabover together. If you were to take off the moldings on the sidewall,front wall joint, after removing all that suspect caulking, which should be replaced anyway, you could access and remove the front wall, which more than likely has a lot of rotted wood in it.
38,782 PostsLatest Activity: Sep 19, 2026
