Mich_F
Feb 09, 2015Explorer
Juzaxadar wrote:
Mich, when you say "molding" do you mean this?
I would have thought that the screws along the outside don't go through the metal frame and into the wall on the other side.
That is what I am referring to. If you go back and look at the picture I posted on 12/1, that should give a better idea of how everything goes together. The molding pieces do screw all the way into the sidewalls frames, and then they are caulked on both edges to seal those seams. The front wall screws into the side wall framing, so with that wall in place, your side walls won't budge.
In looking at your interior picture, it looks an awful lot like mine did, with the wet area along the bottom radius, and 1/2 way up the front wall. If you look at my picture again you will see that the front wall radius is a piece of foam with a lot of scribe cuts in it so it will make the radius bend.
38,782 PostsLatest Activity: Sep 19, 2026
