darsben wrote:
But the real world cure just might be different tires so that being overweight will not cause a failure of the tires.
Hopefully you have front and rear axle weights separated out
X2
Tire failures can be catastrophic. You won't break the frame or the axles running heavy (the front end can wear out faster though). You will have sub-par braking, but you can compensate for that with your driving style.
If you can transfer more weight forward, the 2008+ front axle is rated for 5,000 pounds and also has bigger brakes and an improved radius arm setup and sway bar. QuadVan and Quigley keep new take-off units to re-sell, and this ends up being less than just doing a brake job and ball joint job on your existing axle.
