Has anyone had good luck repairing the area over the cab. We were considering a 2007 Fourwinds 31 ft...but we've found moisture under mattress in the over hang...
10Grands - There have been cases where the clearance lights above where a window would be in the cab-over area are the source of water leaks. Often times removing the lights and sealing the round hole where the wire exits the coach will solve the problem.
