et cetera wrote:
Here is a class C built on a F350 chassic. Not E350. Looks interesting.
2003 Majestic. I assume Four Winds?
Have they made that model beyond 2003?
https://www.usedvictoria.com/ReportSelectUsedAdPhoto2?used_ad_id=33064777&position=2&hb=6
That style of Class C in the link above may make it a bit easier to work on the truck engine ... but when camped how does the driver and/or passenger swing slightly into any area between the two cab seats with their feet and then stand up so as to be able to walk back direcly into the coach without leaving the RV?
That is one of the great things about a van body being used for a Class C with the cab's roof cut away under the cabover and the cabover bed folded away -> being able to rise and go back into the coach directly from the cab. This arrangement even permits the passenger to carefully and occasionally while traveling go back and get something in the coach or go back to the bathroom.
Being able to do the above is priceless to us in our van chassis based Class C.
