navegator
Jun 29, 2015Explorer
What has probably happened is that the dog house was removed to do some work and re-installed wrong, you need to release the four latches the ones on the floor you open the butterfly and twist, the ones on top are a simple latch.
Once you have the cover loose, lift all the carpet around the dog house so that the seal can seat properly, make sure that it seats on both sides and the floor that there is nothing under that seal, now hook the floor lathes and then push the dog house towards the front and secure the latches, this should keep the heat where it belongs outside.
We just had work done on our ford C and the mechanic did not install the dog house correct, I re-installed the the cover and normal temps in the cabin.
navegator
navegator
