Rolin
Jun 29, 2015Explorer
On our 2007 Winnebago Aspect there is an uncomfortable amount of heat coming from the exhaust pipes under the floor. The dog house is toasty, but the floor gets pretty hot on the passengers side. Wife complained that her feet would get hot. Started putting her feet on the Camping World campground directory. The drivers side was not bad at all.
I tried removing the carpeting in the cab area to install insulating material but the carpeting in our unit is glued down very tight. Figured it would pretty much destroy the carpet if I pulled it out.
Plan B was to get some of the Reflectix Radiant Barrier cut it to fit under the Weathertek floor mates and back under the seat on each side. Made a lot of difference. Would like to put insulation under the carpet but will have to figure out how to remove it first.
Our unit has the heat shields. Think they are installed by Winnebago. Must be really hot in a unit without the heat shields.
