JamesBr
May 21, 2013Explorer
Its all about the pressure and nozel spay pattern. I use one all the time, works great even on the roof. Definitely speeds up the process of cleaning the bus by at least half for me.
Basically if you are cleaning anything with a finish and removing the finish, your pattern is too tight for the pressure of the pump and your getting too close. For the RV use a 40 degree tip and do not allow it closer then about 12" from the finished surface, same goes for patio furnature.
Concrete ill use the 25 degree for cleaning an about 6" of distance and stubborn stains im down to the 15 degree.
38,768 PostsLatest Activity: Nov 21, 2015
