Shot-N-Az
May 28, 2013Explorer
If you have patience and don't need immediate results, I can recommend a product called "Wet and Forget".
I clean my fiberglass roof 2X year, in the spring and late fall. My motorhome's roof has a molded-in nonskid surface that loves to hold water and breed mold and mildew. It takes elbow grease and hours to get that nonskid clean.
Last fall I used my power washer on its easiest setting and cleaned the top. Then I sprayed the Wet and Forget on it. The mold and mildew did not return. This spring I reapplied it and the roof still looks brand new. I'm a fan now.
The only drawback to the product that I can see is you cannot do a first time application today and expect miraculous results overnight. It takes awhile for the product to do what it does, but it absolutely performs as advertised.
38,782 PostsLatest Activity: Sep 10, 2026
