- PSWExplorerBefore we had the Sanicom system with the built in tank sprayers I just added to the empty tank a quarter cup of Cheer and a half cup of water softener and then filled it up with fresh water. Then, drove around town stop and go for a few miles, let it set a couple of days, dumped, ran it full of clear water and flushed it out again. The sensors then seemed to work pretty well for quite a while.
- KristinUExplorerJust caught this on another thread:
wkswenson wrote:
This is an older topic - but an update on the Horst Sensors - Valterra has purchased the company and will be re-introducing those sensors under their brand soon. - KristinUExplorer
Stefonius wrote:
icanon wrote:
I've wanted to buy and install the Horst Miracle Probes, but haven't pulled the trigger yet. I'd love to hear some first-hand feedback from anyone who has them.
Some people swear this solved their Sensor problem.
I have never used it but it seems logical.
We installed them on our TT and we liked them very much for the 6 or so months we owned the TT before trading it in for our Winnie with the stock TrueLevel sensors. So I can't speak to longevity with it, but they sure seemed to do the trick for the time we had them. If we were to buy a new camper without TrueLevel I'd install the Horst again...it would be super ideal to install them on a brand new tank before use if you catch my drift...but anyone who has dumped tanks or changed diapers or picked up after their dogs should be able to stomach the job on a used but empty tank.
I posted about it on our TT blog, though I don't know if I said much more than I said here :) http://visaadventures.blogspot.com/2013/01/poopy-talk-macerator-and-tank-probes.html - StefoniusExplorer
I have never used it but it seems logical. - jfkmkExplorer III also do not have a tank cleaner but use a wand. The cons of the wand are you have to drag it through your rv (I clean it with Clorox wipes) but the pros is you can move it up and down and get the entire tank.
- DrewEExplorer III
larrydp wrote:
Those of you that use the wands, do you use them in addition to a built in tank cleaner?
Nope. I don't have a built-in tank cleaner, which is a big part of the reason why I have the wand. - larrydpExplorerThose of you that use the wands, do you use them in addition to a built in tank cleaner?
- ron_dittmerExplorer IIIWe have the typical simple design tank sensors in our 8 year old motor home and they still work well. I can't say if this is the reason but I bleach the tanks at the end of the RVing season to control sewer gas because the rig is parked indoors under our master bedroom as shown here.
- Had two Tornados break and leak and had questionable effectiveness. Now have Nofuss Flush with custom spray pattern to direct water at the sensors and back of tank. OEM sensors are now working like new.
- ronfishermanModeratorGave up on the sensors. Installed a SeeLevel system a few years ago. So far they have worked well. When Stuff collects on sensor walls. A short flush with Tornado Tank Washer and all is back to normal.
