OFDPOS
Apr 15, 2015Explorer
I have used goof-off with ample success on the black streaks both on the moldings , and caulking around windows to the black streaks from the roof on the sides/back of MH etc.
I just use rags.
First damp (dripping) a small spot of the rag with goof-off now with finger press against area for it to work in , then work back and forth. Now on a clean spot of the rag get wet again with goof-off and work in one direction. Final step over again as mentioned step 2 final wipe and pretty close to new looking.
Any time using any kind of chemical on any surface do a test spot first , and always put a coat of wax on any painted surfaces you use cleaners on..
I just use rags.
