ROYBUCK wrote:
Got on top of MH a few minutes ago to clean, I have a mess up there mildew and dirt, soap and brush won't take it off I have tried simple green I would need to get down on my knees to do this due to my handicap  I can't do this. Does any one have a suggestion that won't hurt the top.  Thanks  Roy
ROYBUCK,
 Due to your limitations, the method I would suggest probably won't work for you. But, if you could possibly find some teenager, pry them away from their phone or, video game and, tell them to:
1. Wash with a good sponge and either Bar Keepers Friend or, any cleanser will actually work. You won't do any harm to that surface. It' a lot tougher than most people think.
2. Then, use a "buffer" and a RUBBING compound on the entire roof.
3. Then, use the same buffer and a, POLISHING compound on the whole roof.
4. Then, a wax coat with just about any auto wax will be fine.
    Again, this method is hard and laborious. Not many would even think about doing it. I've done it more than once. The results are nothing short of outstanding. It will last for about two years, plus or minus, depending on how much weather it sees when you're not using it.
I'm not a big fan of floor coatings on roofs but, that's just me. Everybody's got to do what's preferred by them and makes them happy. Good luck.
Scott
