Tom_Barb
Oct 02, 2015Explorer II
s N s wrote:
Guys, what's the best way to remove the clear coat? On ours we have sections where it is peeling and then sections that are still OK. If possible I would like to remove it all and just buff and polish it if that's possible. Thanks.
If it is not loose, it does not need to be removed, I used a pressure washer to blow off the loose portion, and then buffed the area.
You really don't have to get very close with the pressure washer to get under the loose clear coat and take it away.
