bobndot
Feb 02, 2021Explorer III
CharlesinGA wrote:Cmccain13 wrote:
So I'm in a 2021 coachmen leprechaun 300BH, water heater is on the other side of the coach and the propane was on. that's what I was thinking but the fridge should be able to run off the coach battery when im driving right? and it was in auto position so maybe something was going on and it was trying to switch to propane just not working.
Only if you have a three way fridge, and they are not particularly common. Most three ways have a separate button to turn on the 12v heat element control. If you set it to auto, it will try to go to gas when you remove shore power.
Charles
I would never recommend for anyone to run in the 12v mode of a 3 way fridge , the amp draw would be in the 25amp range opposed a compressor type 12v fridge at 2 or 3 amps.
38,782 PostsLatest Activity: Aug 23, 2026
