sch911
Jan 11, 2016Explorer
If you keep the RV plugged in to 120V also it could be the on-board converter cycling on and off trying to charge the same battery. Generally if the RV is plugged in the batt's get charged and no trickle charger is needed. Only caveat is if the onboard converter is not a smart charger in which case it can sometimes overcharge the batteries.
38,782 PostsLatest Activity: Aug 23, 2026
