Mrgunguy's avatar
Mrgunguy
Climbing steep grades...
I have a 30’ 2003 Four Winds class C with the 6L, 8cyl Vortec engine. I’m planning on pulling a 2003 Jeep TJ (4cyl, straight drive) and had a question or two.
I’ve noticed that when I’m climbing steep grades (or even not so steep grades) the engine has a tendency to begin heating up. I’ve been told that this is due, in part, to the overdrive and if I simply kick it down to 3rd gear I should be able to mitigate some of that heating. So far, so good. It does heat up some but not as quickly as it used to and it has not left me on the side of the road with a smoldering engine.
Now I would like to flat tow a small Jeep so that I can run about when I get to where I’m going but I’m afraid that this will be too much and the coach will overheat when I’m 1,500 miles away from home and on the side of a mountain. Is there something that I should be taking into consideration or doing differently? We would like to go to see Yellowstone this year and, at an elevation of 5K+ feet, I’m feeling anxious over having to climb an awful lot of asphalt.
Any help or advice would be gratefully accepted.
