navegator
Nov 28, 2015Explorer
One source of cluncks can be the transmission mount, if there was any trans fluid leaked it has made the mount mush and you get metal to metal, most probable a U joint.
To check the U joints, park the vehicle in a level place, chuck one rear tire and one front tire really chucked, parking brake off, transmission in neutral, engine off.
Crawl under and move the U joint up and down, rotate 90 degrees and check the other U joint, there should be very little side to side movement, anything else the U joint is toast and needs replacing.
navegator
navegator
