DrewE
Aug 02, 2018Explorer III
I assume by "coach" you mean the chassis battery. (Coach battery usually refers to the house battery.)
2A, even intermittently available, ought to be sufficient to keep it charged if there is no load beyond typical vehicle parasitic draws. I'd suspect something left on, like maybe parking lights or some gizmo plugged into a dash lighter socket or the dash light, or else some fault or incorrect wiring up causing a battery drain.
Maybe, if you have a BIRD sort of isolator (a bidirectional relay control, so it is designed to charge the chassis battery when the house battery is being charged), it's getting confused by the charge path around it from the solar controller and activating most all the time...though I don't see how that could run down the chassis battery so deeply.
