theoldwizard1
Aug 03, 2018Explorer II
Instead of "shooting in the dark", spend a few bucks and get yourself a digital multi meter with an amp clamp. Many to choose from on Amazon, such as Uni-T UT210E.
When searching for electric current "leakage" (Where is the power going ?), the othe method is to use your volt meter and probes to check the voltage drop across each fuse. All plug in fuses have 2 little spots on top. Just touch each spot with a probe. Ideally it should be ZERO if everything on thar circuit is turned off.
