FIRE_UP
Aug 03, 2018Explorer
was_butnotnow wrote:
I know there is no charging of coach batteries from charger/inverter or shore power only when engine running. But do have that 2 A charge from the solar controller to the coach batteries.
By the way, they are new.
I can start the MH with the power boost turned on and charge the coach batteries up but then they don't hold that charge.
Will look into getting a more powerful trickle charger for the coach batteries. Anyone recommend a good full-time coach charger that I can run off of my house batteries or inverter. The inverter is always on when not on shore power do to a residential fridge.
Well,
You don't say how long it takes, from the time you shut down your engine, with a fully charged set of CHASSIS batteries, to drop to your lower voltage of 8 or so volts. Hours, minutes, what? The shorter the time frame, the stronger the short or draw there is on them. If it takes DAYS, well then, trying to find the culprit may be a bit harder. But, to simply provide a LARGER CHARGER to try and over power the draw, is not the answer here.
As has been suggested, get out your trusty volt ohm meter and start testing where tests are needed and results can be found. Once the culprit is found, your need for a LARGER battery charger will be greatly diminished. Will your CHASSIS batteries still need a charge while on shore power, sure they will but, only enough charge to overcome the parasitic draws that are standard in many of our coaches.
And that means, pickup either a Trik-L-Start or, it's bigger brother (recommended), the Amp-L-Start. The Trik-L-Start allows a maximum of 5 amps to be diverted to the chassis batteries if and when needed. The Amp-L-Start will allow a maximum of 15 amps to be routed to the chassis batteries, if and when needed. Even though I recommend the larger or, more amperage unit, it is not because of trying to overcome a potential high amp draw, it's because I'm one of those types that, if the 5A unit works, the 15A unit will work just that much better.
If you're not aware of how either one works, it's simple, whichever one you might choose, it ties into both sets of batteries and, when the CHASSIS batteries become even .5V lower than the HOUSE batteries, then which other one you chose, will jump into action and divert SOME of the amperage intended for the HOUSE batteries, and send it to the CHASSIS batteries. This is the most logical choice for these type situations. By the way, the Trik-L-Start or the other ones, is only powered up when shore power is connected and, your inverter/charger is charging the HOUSE batteries.
Scott
