MountainAir05
Oct 21, 2015Explorer II
As stated you have a open, or a loose connection. Next time you loose power, If I understand , you have power if engine is running, If that is so then check you relays .
1. check battery voltage, working your way back to power junction.
2. Check your power connectors in the power block "where every it is located.
You might check you Couch power switch locate at the door on mine. I have a different RV but if I turn off the couch power and crank engine I then have 12 vote power back to system. Turn off engine and power is lost.
38,763 PostsLatest Activity: Dec 05, 2025
