two_travelersExplorerNov 03, 2015Coach seems to be shrinkingWe have a 2008 Winnebago on an an F53 chassis with 53K miles. Shortly after we purchased, I measured the coach at about 12'3". Recently measured again because we had a low bridge to go through. This t...Show More
FiestaExplorerNov 04, 2015Did you use cm's rather than inches this time? Were you at a lower elevation?
Related ContentShrinking Canadian dollarShrinking the TruthShrinking AwningShrinking trimCoach battery seems drained after using generator.
