WILDEBILL308's avatar
WILDEBILL308
Explorer II
Nov 25, 2016
Coach with no slide outs
There have been several people posting in the past that wanted a coach with no slides. I was looking at something else when this popped up. I think if you are looking for a premium coach with no slides this is a steal. It is a 1996 Foretravel. For those who don't know I would consider Foretravel to be one of the top 5 makers.
http://kennedale.rvusa.com/1996-foretravel-u295-36-diesel-used-class-a-tx-i1975638
I just thought I would share.
Bill
  • garyemunson wrote:
    Just a question.. We've had 5 units (1 TT, 2 Class Cs, 2 Class As) over the years with slides and have never had a leak. I've always made it a point to keep the top/bottom/sides of the slide unit clean and regularly use silicone spray to lubricate the gaskets (making sure to clean them off on a regular basis, too). That, along with making sure the rollers under the slide were kept lubricated always kept them working like new and watertight. Having lived in Florida most of my life I have driven/pulled them through some serious rain without issue. We now have a Winne with the seemingly tiny Lippert slide system. I'm following their maintenance procedure and after a year, so far so good.......
    I think you hit the nail on the head...just like everything else, preventive maintenance is key!
  • Just a question.. We've had 5 units (1 TT, 2 Class Cs, 2 Class As) over the years with slides and have never had a leak. I've always made it a point to keep the top/bottom/sides of the slide unit clean and regularly use silicone spray to lubricate the gaskets (making sure to clean them off on a regular basis, too). That, along with making sure the rollers under the slide were kept lubricated always kept them working like new and watertight. Having lived in Florida most of my life I have driven/pulled them through some serious rain without issue. We now have a Winne with the seemingly tiny Lippert slide system. I'm following their maintenance procedure and after a year, so far so good. Do most agree that slides need an extra amount of effort to keep working/dry and that paying attention to that rule makes problems unlikely? Over the years there have been a few times where I've heard someone's slide extending or retracting noisily and have wandered over to point out to the owner that a bottom roller was seized up or the slide sides were filthy and/or gaskets were covered with dirt and dry. I really suspect that owners who are not sufficiently aware on what's needed to keep slides working right are the cause of most trouble.
  • After 2 leaker's in the past, we looked specifically for a no slider. We found it and are happy so far.
  • There is certainly a group of people, even on the Prevost site, that prefer to have 'no slides'. It does take out a cost-element of motors and seals.
    My understanding is that a Prevost air-seal replacement (maybe Foretravel too if air filled) can cost $5,000 per slide.
    Sometimes simple is better.
    MM.
  • enblethen wrote:
    Not for $40,000
    Clicky
    Thanks for posting the Clickey! Some say a RV with less moving parts is better? To each his own!
