I’m replacing the motor on the coach/Lippert electric steps. I cants get the mounting screws to lineup. Any suggestions on what I’m doing wrong. Thanks in advance for any suggestions. Mike
They do line up, but you have to be EXACT. It is very frustrating. You have to line up all 6(3 pairs) bushing barrels and then run the bolts thru. I use a cordless drill with the 10mm socket to help. I also soak the upper area with WD 40 before removing the old motor bolts and then liberally spray WD 40 into the threaded slots. Doug
