KennyBoy's avatar
KennyBoy
Coachman Freelander 21RS- Fresh water drain
I am looking for someone who has the same model to validate Coachman's instructions.
Coachman tells me to open the rear storage compartment and take off the left panel to find the drain. They are also sending me a new panel to replace the one I am taking off. Then, they want me to cut a hold in the new panel and replace it. Have you heard of any more ridiculous? Time to winterize!
  • Our Frelander QB had a similar setup. I removed the large panel, cut an access panel and used a short piece of piano hinge to reattach the access panel. Now when I need to access the drain points, I just open the port that I installed.
  • On mine, I open the rear compartment and against the front wall is a 4" removable plug and I can access the three cutoff valves.
    Marvin
  • i have a freelander qb, all my drains are behind the big drawer under the stove, of course i do not have a oven.
  • My low point drains and fresh water tank drains are behind a panel in the under bed compartment accessed from outside in my Prism. I simply removed the 4 screws that held it in place, and added a couple Velcro pieces instead. Silly location for the drains, but easy to access now.
