I have 2013 Leprechaun 317SA and do like it, however I have had serious water leak issues that required it to be is the shop 123 day the first year I owned it. The 319 is basically the same unit, especially in the cab over area. That is where the water intrusion problem seems to be in these motorhomes. I have had communication with quite a few other Leprechaun owners with the same problem, plus the technicians at my dealer had told me in confidence that the issue is wide spread and continuing. If you are serious about buying one of these used, insist on inspecting the inside of the front cap for wet or missing insulation and damage to the bunk deck. That is the easiest way to tell. I would also be skeptical of this unit on such a fast trade off. The person may have bought it, discovered the water problem and decided to quickly cut his losses. I finally have mine water tight, or so it seems, but if I had known then what I know now I would have run the other direction. If you need more information please feel free to email me directly at
[email protected].
