loggenrock
Sep 27, 2017Explorer
Low point drains do NOT drain the fresh water tank - that's another valve. Low point drains allow water in the lines to drain - you should have both a hot and a cold drain, in addition to the water tank drain. 3 total. I have a 2015 Prism 24J - the valves are small T-handles that pull up to open. Lousy placement, they are behind a panel in the under-bed storage compartment. They will drain onto the ground. Mine happen to be just behind the passenger side rear dual wheels. ST
38,782 PostsLatest Activity: Aug 11, 2021
